help with hooking up highs.
theboiyo187
Hi all im new to the site and also a newb to car audio. So everything for this project is all budget an low end products. I've seen numerous of people do regular amp and sub installs so i knew how to run that. My thing is how to wire and run a amp for highs. I've tried google and youtube and just couldnt seem to find how the wiring from the head unit to the amp goes. Any help would be appreciated.
How many RCA out puts does HU have if any? If it has fr/rear/sub use a set of RCAs to the fr and rear channels. If only 1 set of RCAs available use a splitter or a line converter to get the amount of inputs you need. Use High pass filter on amp. Are you using Components with a xover ?
190
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
207
455
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
277
theboiyo187
theboiyo187
york,Pa
theboiyo187
    Apr 28, 2024
    Apr 28, 2024
