Help to find out tuning freq for 2 subs
Beginer
Hello,
Some months ago I made box for ONE (1) Type R subwoofer.
I made this box:
Net Volume: 3cu.ft
Tuning Freq: 30Hz
Port Width: 3.25 inch
Port Area: 40.625 square inch
Port Length: 35.25 inch
http://i47.photobucket.com/albums/f200/Scarrell/boxdims.jpg
Now I want to put TWO (2) Type R subwoofers to same box.
So how can I calculate what will be tuning freq with two Type R's in this box?
Port width, area, length will be same.
It would be great if you could explain how to calculate that tuning freq //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks.
so you want to put 2 type-r's in the same box that you had one type-r in?
I assume your talking about 12's.
So basically the only thing that would be different is the .071 displacement of the second sub.
Comes out to 2.781net@31.1hz. Your initial calculations were a little off or something.
2.8 @ 31hz.
The enclosure's tuning frequency is based on the port area, length, and net volume. The only thing that changes when you add the second sub is the net volume and by a very small amount.
That enclosure is probably going to lose a little bit of low end and get peaky around 40hz with two subs in it.
Yes I want to put 2 Type r's 12" to same box.
you will notice that the box lacks the low end it once had though... new box time
WHAT!!!! That's a load of nonsense.
He'll still have the low end he had before, the addition of the second subwoofer ain't changing the port tuning to any great difference of increase.
Add the second subwoofer and see how it sounds, then decide for yourself if building a new enclosure is worth the effort, just don't go building a new enclosure thinking that it's going to change any of the bass/performance response from what you have presently.
mainly because now two subs are sharing the "3" cubes instead of one in three cubes. take 1 sub in three cubes and one in 1.5 and see how different they sound. i'm not saying it will lose or gain anything, just that it might sound different and you might not like it. or on the other hand you might love it. personally i would build a new box.
OK, in that I would agree 100% given the volume is now split for two sub's and the output is definitely going to increase along with the F3 of the sub/enclosure.
Well I could agree with you. I will lose low notes. So this mean that box will be tuned higher. This is what I'm seeking. I want to make SPL box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It was SQ box because was tuned low and was playing low notes. And if I put second subwoofer I will lose low notes. If I lose low notes it will mean that box tuned higher. Agree?
But I don't believe that tuning freq will increase only to 31Hz...
Are you guys sure that only subwoofer dispacement will affect tuning freq?
Well I could agree with you. I will lose low notes. So this mean that box will be tuned higher. This is what I'm seeking. I want to make SPL box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifIt was SQ box because was tuned low and was playing low notes. And if I put second subwoofer I will lose low notes. If I lose low notes it will mean that box tuned higher. Agree?
The port tuning is effected by the Net Volume, Sub Displacement, Port Size and Length, plus any other displacements = Port Tuning.
Change any of these and your port tuning changes, by how much depends on which program you used to design the enclosure to get the spec's.
your tuning will still stay the same, but your frequency response will change. 3 cubes at 30 hz will have a different responce than 1.5 cubes at 30hz. it depends on the sub. try playing with winisd to see how the different volumes affect the response curve.
the box won't be tuned higher but it will probably peak higher because of the smaller port gain(which is centered at tuning frequency) of 1.5 per sub instead of 3 per sub.
You probably will lose some low end, but you'll also probably get a flatter response than before as well.
Well tryed to play with WinISD.
And if I set 3cu.ft box with 30Hz tuning and ONE sub. So peak is at ~32-33Hz.
And if I set 3cu.ft. box with 30Hz tuning and TWO subs. So peak is at ~44-45Hz.
So if I get peak at higher frequency this don't mean that tuning freq is higher? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Because I played with WinISD and before and noticed that peak is ~3-6Hz higher than tuning freq. If box is tuned to 40Hz so peak is at ~43-46Hz.
Well tryed to play with WinISD.And if I set 3cu.ft box with 30Hz tuning and ONE sub. So peak is at ~32-33Hz.
NO, it just means that you dB response increased, but, that will be effected as well by the cabin gain frequency of the vehicle as well,however, since your looking to increase the SPL response, you just might like the end result.
Keep in mind that were talking in generalizations here as to what is going to occur, the true measure will be cut for the second sub, mount it and stick it in the vehicle and then determine the result for yourself.
So tuning freq will be the same. Understood.
With two subs dB response increase and peak will be at ~44Hz(with one sub at ~33Hz) by WinISD curve.
Ok. Let's say I will play 44Hz tone.
And let's say we have two boxes:
1st. 3cu.ft tuned to 30Hz with TWO subs
2nd. 3cu.ft tuned to 40Hz with ONE sub
So if we play 44Hz tone with 1st and 2nd box, we will get more dB's with 2nd box right? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Sorry that I'm asking so much, just trying to understand everything //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, Naturally your going to get a given amount of db's increase if you up the port tuning, but only in terms of the peak response in vehicle.
SPL is going to increase as well and at what point it hits with a 44 hz test tone to the cabin gain frequency is where your going to hit at and if your aiming for the highest possible SPL/db gain, your going to need a meter to measure that to determine that if your goal is to compete.
He!!, I know someone that has been trying to break 150 for the pass couple of months and tired different enclosure's at different port tuning freq's using the combo of subs and amps and finally broke 150 yesterday using 2 subs and one amp.
So, it really all boils down to experimenting with the combination of subs/ enclosure design to find what your desired goal. Your not going to hit it first time right out the gate.
Yea I know that I need to experiment, but I think that then you know basics you can reach your goal easier.
He made 150dB with two Type R's?? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Beginer
Beginer
Europe
Immacomputer
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
