Help please!!
  • 4
So I'm broke and don't have money to spend on an expensive amp but I got a bose amp out of a 2000 Olds Intrigue I beleive. All I want it for is for my 2 fronts and 2 rear. Front are 2 ways 5×7 Infinity and rear are 2 3way 6x9 Ingintiy. Does any know where I can find,the wiring diagram for,this amp, also best way to hook it up as I have never hooked up an amp before and is it foolish to have 2 ways and 3 ways in same system. I di,have 2 tweeters if need be.
I know its a lot of newbee stuff so I really appreciate any help or advice.
Yeah its a factory amp put of an oldsmobile that I want to use in my car
You are going to have to find the Oldsmobile factory schematic on what all the wires coming out it are for. then you have to figure out how you are gonna connect all your speakers optimally to this factory amp.
Sorry I can't be of more help for you with the information I have from you at this point.
John Kuthe...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Pterinochilus
Pterinochilus
Augusta, Ga.
JohnKuthe
    Jun 1, 2024
    May 31, 2024
