Help please!!!!!
yroc434
Va
ok so here is the description of my Ported Box
width: 38"
depth: 14 & 3/4 "
height: 14''
Gross air space: 1.71 cu ft per chamber
Net air space: 1.48 cu ft per chamber
port volume: .23 cu ft
tuning : F3= 29hz, ripple= 4.4db, FB= 35hz
ok so i have (2) 12'' Type R's (SWR 12D2) and some songs they sounds great and hit hard but other songs there is hardly any bass and doesnt sound as great. Definitely doesnt hit low notes well at all. Can anyone tell me by these specs on this box if this box is any good for these subs or should i look into getting a new box?
my amp is a Hifonics BRX2000.1D and its rated at 1400 rms x1 @ 2 ohms and my subs are wired to 2 ohms. my gain i set just under half way and my bass boost is all the way down, my LPF is set around 100hz..... is it my box or are my setting set up wrong?????
Name some songs that you play that hit hard and some that does not hit hard.
What is the subsonic filter set at?
next how is your box positioned and what car is this?
Is it a custom handbuilt box or something bought online?
Specs dont look good, too small and too little port area
Proper gross volume for a 1.5 net slot port is around 2.1 to 2.3 cubes gross
I'm thinking either too much or too little port area. What are the port dimensions?
Too much could yield a very small bandwidth, causing some songs to "hit a lot harder than others".
The box may have a "peaky" response curve
I play like A lot of rap example.... (Dont hit hard) put on by young jeezy, amilli by lil Wayne, ocho cinco by French montana..... Ones tha do hit hard are like Paperboy by Hell Rell, aston Martin Music by Rick Ross, throw it up by lil Jon.... My SSF is set around 80-100..... Its a box that was bought offline
Also its in a 2005 Nissan Altima and its facing out the trunk meaning if you pop the trunk you see my subs and not the back of the box
Yeah man box is not good. Like auldbrich said, too much port area can be bad but not enough will be just as bad because of port compression, you are losing out on lower notes from too little port area and not enough airspace. The subs themselves take up room in the enclosure, enough room to drive the tuning up a whole hz.
Cscstang is doing a dual type R build for a local guy, he does great work, hit him up for a box man.
My box is tuned to 30hz and a mili doesnt bump for SSHIT! It doesnt even have bass lol your bandwidth might be the issue. Maybe its tuned low or as stated above the port area is wrong. Also i hope your lpf is set to that not your ss although i dont think any ss goes that high
Put on gets low. That was my favorite song when I had my SA8v2 in my car. People were like, "holy shit, that's an 8??" My box was tuned to 27hz
A Milli is a bit higher. Aston Martin Music bangs too.
Ditch the pre-fab
A Milli slams in my car right now man.. Trust me, it has bass, haha
yroc434
yroc434
Va
yroc434
