Help Please!!!!
The subs are dual 2 ohm voice coils and they are both wired correctly as well as the power and ground. The fuses only pop as soon as I start to bring the volume up. Could it be posible that the fuses are popping because my subs are too weak for amount of power that the amp is giving them. It doesn't make sense to me because if that were the case wouldn't the subs be blowing and not the fuses?
did you check the power wire like stated? Obviously something is touching bare metal causing a short in your system.
yea. something is obviously wrong.
if u say u checked it, well, you didnt check it well enough.
There is an issue with your wiring.
If u cant see it easily, take it all out and re do it.
make sure ur wire is cut to proper lengths, make sure nothing is able to touch any metal, etc etc.
x1000
What head unit do you have btw?
Yeah. Thats what I was worried about. It seems like everytime I buy a new piece of equipment for my system it requires me to completely gut my trunk out and re-think the instalation.
ashtrey1212
Gimmie Some Sugar Baby!!!
ashtrey1212
Amherstburg, ON
ashtrey1212
