help please
  • 4
Make sure you ran your rca cables away from the power cable.If their together they interfere therfor you here that pop noise.
rcas are on one side and power is on the other but my hu is hard wired to the battery does that have something to do with it
991
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
943
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
btlking
Registered User
btlking
Uranus
btlking
    May 12, 2024
Brendon Jenness
    May 11, 2024
