Help please :Just 2 Questions
hoodkid
Got bang?
wut up i'm working with 2 ppi dcx122's subs, and wanted to know 2 questions.
1. These subs are 4 ohm, so could i wire each sub seprately in parallel, and hook each sub to it's own channel, so it would be 2 ohm load?
2. and secondly but should i go ported or sealed for these subs, im realy try'in to hear some good low's
oh and here's the speakers specs.
http://precisionpower.com/subwoofers/DCXseries.asp
Assuming each sub has dual 4ohm voice coils; yes, you could wire each individual sub in parallel and wire one sub to each channel (of a 2 channel amp, I presume) for a 2ohm load on each channel.
Going by the specs on those subs; I'd stick to ealed with them.
I would also recommend an eeled enclosure...
Well i got a question about the box, based on the info about the subs
Driver Physical Dimension
______________________________
Mounting hole diameter (inches) 11.25
Mounting depth (inches *) 7.75
Basket diameter (inches) 13
Model Number DCX 122
Recommended Enclosures
___________________________________
Typical sealed enclosure (cu. ft.) 0.95
SPL sealed enclosure (cu. ft.) 0.8
Low Qtc sealed enclosure (cu. ft.) 1.5
Vented enclosure (cu. ft.) 1.45
Port tuning frequency (Hz) 40
Port diameter (inside, in.) 4
Equivalent square port (in.) 3.54x3.54
Port length (in.) 9.06
I have been told that 0.95 sb ft is to small for a sub like this, or should i get a 1.5 cu.ft box?
hoodkid
Got bang?
hoodkid
detroit
stones
