D dru3692 Junior Member 1 0 dallas, tx Jan 28, 2004 #1 I have a Legacy 400 4 channel, dont know much else about the amp, but im trying to find out what mids and highs or tweets to get. also running 2 12" JL w3v2 with JL 500/1. speakers, equalizers, crossovers....??? Click to read more...
O outbacksport 10+ year member Senior VIP Member 309 0 S Cal Jan 29, 2004 #2 Why not stick with JL Audio dru, the XR650-CSi are $269 now at onlinecarstereo. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=11421 or you could check out their new sets, the ZR650-CSi. ZR650-CSi Nominal Woofer Diameter: 6.5" (160 mm) Woofer Mounting Depth: 2.63" (67 mm) Woofer Grilles: Included Tweeter Size and Type: 1.0" (25 mm) Aluminum Dome Tweeter Mounting Depth: 0.40" (10.3 mm) Continuous Power Handling: 85 W per channel Recommended Amplifier Power: 40 W - 175 W RMS / ch. Nominal System Impedance: 4 ohms System Efficiency: 89.5 dB @ 1W / 1m System Frequency Response: 48 Hz - 25 kHz ± 3 dB
