help on deciding an hu
  • 5
nas786
hi guys
i'm kinda new to this stuff, and have asked this question many times, but never got a straight answer
if i'm going to run aftermarket amps for all my speakers, what difference does the head unit make??
what are the things i am going to look for when deciding what head unit to go with??
i plan on running three amps, usamp1000x (1000 watts at 4 ohms bridged), usamp400x (2X100 watts at 4 ohms), and another amp for my coax (somewhere at about 2X75 watts)....so if this gives any insight as to what i should look for.
i just want to know what hu would be best, i would hate to spend $$ on amps and speakers and all that, but limit my system cuz of a crappy hu.
i have no clue as to how much to spend actually, i'll probably just look around for a deal
but, i want to know, if i'm planning to run 3 amps of the hu, then the hu must have certain things, right, in order to be able to run these things off of it....i'm really not sure
so, would i need an hu that has 3 seperate rca outlets, so that it plugs into 3 amps??
as you can tell, i'm quite lost
o, i'm thinking that i might get a touchscreen, if i find a deal on a used one
ok, cool....actually, i think i worded the thread in a bad way....i don't actually want suggestions on which hu to buy, i just wanted to know what would be necessary in the head unit i buy, thanks for the info
do monitors usually come with those three outputs??
o crap, i just realized, i forgot to ask ....
how does headunit affect the overall quality of the system??
i'm running aftermarket amps and aftermarket battery, the only connection is from the hu output to the amps, but does this make a difference as far as sq or spl??
so what tells me that the headunit is good, or if its going to handicap my system?
generally if its a good brand name eg alpine/eclipse/pioneer/etc... and one of there higher models it will b good, not 1 feature makes it good its a compilation of everything, pre-out voltage, sensitivity, eq settings, etc......
ok, which one is better??
preout voltage of 5.0 v and resistance 80 ohms
or
preout voltage of 4.0 v and resistance of 100 ohms
...right now i'm thinking the 5 volts, but i'm not sure if higher resistence is better for running to amps
how big of a difference does the preamp voltage make??
i'm looking at two decks, one has 4v(clarion DXZ945MP) and one has 6.5v(premier deh-p960mp)....i like the looks of the clarion a lot more, but the pioneer premier has higher preout voltage, and i really want to get the full potential out of my system. does that 1.5v really make any type of noticable difference??
both cost the same, so price does not play an issue here.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
273
234
nas786
nas786
central cali
nas786
    May 24, 2024
    May 23, 2024
