HELP! New Amp Necessary?
  • 2
ntascrname
Virginia
I'm putting in a cd player, 2 6.5" component speakers in the front, 2 6.5" regular speakers in the back totaling about $500.
Do I absolutely NEED a new amplifier to go with my speakers and cd player or can I make use with the factory installed amp. A matter of fact, what exactly does an amp do!? I'm really clueless...
Can I still get decent sound and solid bass without a new amp or is that pretty much required. Right now the whole system is the good 'ol factory 95 accord setup. I have no need for earth shaking bass or ridiculously loud volume, mainly I want semi-crisp sound with decent bass.
Please explain/advise.
Thanks,
Ntascrname
well u will get decent sound with just the headunit . but if you were to just pick up a 4 channel amp and hooks those babies up the sound quality and power will dramatically increase. but it should sound pretty good with just the headunit
it should sound fine with the head unit but if you want really good sound by a amp may one with 60 watts to all 4 channels it would sound much better than the head unit
642
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
406
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
774
ntascrname
ntascrname
Virginia
muffmanaj
    May 16, 2024
    May 16, 2024
