Help!!! My subs cut out only when i close my trunk.....
Grand Merk
I have 2 cvrs in a middle slotted ported box. So i turn up the volume everything good until i close my trunk it starts cutting out...so i open the trunk again and the subs pounding good....so i check my ground, power, gain etc...and everything good..i close the trunk and they start cutting out again..so i pop the trunk open and i put a 2x4 over the ported slot to cover it and the started cutting...is it the box or the subs??? any suggestions??
you silly little fucker, i was being serious. All he needs to do is rub sun tan lotion on them and they will be fine //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
the man speaks the truth..... spf 30 will do the job
Grand Merk
Grand Merk
Chicago,ill
nateberrier
