help me with 1st setup before i go crazy
EviLLLLSiNz
Well, here you have it. help me piece together a sub, box, and amp for under 300 dollars. I have in integra and I'd like to keep my trunk space, so I was thinking either 1 12" or 2 10" (maybe 1 10"). I listen to mostly rap, dance, techno, trance. I want to still retain my trunk space so my max dimensions in length would be 30" and the max height would be 15" and the width I would like to keep at most 12" (If the box doesnt span across the whole back of the trunk then it can be more than 12"). I have an integra, which is a hatchback. I'm going for a sql application. what do you guys suggest? this is what I have come up with:
1.
Diamond Audio D312D4 12" 800 Watt Dual 4 Ohm Subwoofer
PROFILE AP1000M 1000W MONO AP California Amplifier with Remote Dash Mount (500w rms @ 2 ohms)
Ported Custom box (6 bux for plans and 40?? bux for supplies,,, i dont know how much the supplies are going to cost >.
2.
12" Alpine Type R (2005) DVC 4 ohm
Ported Custom box
EDIT: this local guy is selling 2 of the CVRs for 115. they are new.
3.
2 10" Kicker CVR DVC 4 ohm (300rms each)
Profile AP1200 2 Channel 1200W Amp (RMS Output Power (2 Ohms): 300W x 2 )
Sealed Custom box
4.
2 KENWOOD TORNADO 10" 1400w CAR AUDIO SUBS (350rms each)
Sealed Custom Box
5.
2 Pioneer TS-W256DVC 10" DVC Subwoofer (350rms each)
Sealed Custom Box
EDIT:
6. 2 Infinity Kappa Perfect 10.1
Sealed Custom Box
7. Infinity Kappa Perfect 12.1
Sealed Custom box
what are the pros and cons of each setup? which one would you chose? or would you go with another setup alltogether and what setup would that be?
I just want to put the system in and be done with it, satisfied with the amount of bass I get.
I'm also planning to use scosche wiring (walmart stuff) then just buy some better expensive cables to connect the amp and subs.]
from what ive heard i need a better amp? need amp suggestions!! plxz!!
Well, since you said alpine
Alpien works well in smaller ported boxes
And Alpine Type X in a 2.0^ft ported box would be nice. You could probably get away with 2.0 gross, as long as it's above 1.5 after displacements.
Awesome SQ and pretty decent output.
Brand new they're under 250, IIRC. Can find an amp for them and not kill yourself trying as well
ur not ganna be able to go diomand audio with ur budget
you can get this sub for an average of about 100 bux.....
please do not post replies that dont even help me... seriously! i just want help decided and be done with it!
where are u getting ur stuff?? i think i need to check that place out too.. im still on the lookout for an amp for my speakers
EviLLLLSiNz
EviLLLLSiNz
Bay Area, CA
Jdizzle
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
