help me please
Fordfool302
Please help me with with this voice coil wiring drivin me crazy I'm about to go outside and wire my spekars differently. Ok her it is I'll do my best to explain this sh*t. alright dual 4 ohm speaker for 2 ohm load I have + to+, and -to-. then from the amp I have + and - to one voice coil, it this right or does + go to one voice coil and - go to the other voice coil, and it this is wrong what effect would it have.
Thanks alot to who ever can help my dumba**
So the 2 different ways I explained it to be I will get a 2 ohm load either way because it is just like the picture you posted exept the + and- negative form the amp are on one side voice coil only instead of + to one voice coil and- to the other voice coil.
Thanks dued
Just as long as the connection from the positive amp output is connected to both positive coil inputs (regardless of how you choose to achieve that) and the same for the negative amp output to the negative coil inputs you'll be golden //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fordfool302
Fordfool302
Asheville,NC
Prowler573
