HELP Me Please Before I Ruin Some Subs!!!
SoCaL081
50
Hey everyone I'm needing some help with my subs before I ruin something. Anyways I have one eclipse Sw6123.4 svc 12", also one eclipse sw8102dvc dvc 10" and a Alpine MRD-M1000 amp to power them. Anyways rhe subs are in separate boxes and was wondering how I should wire them up to my mono amp? On the svc it would be red to red black to black but the dvc wired as? Or am I even able to run both? Hopefully someone can help. Thanks!
Well title does state before you ruin your subs, how should they be wired.....can't wire up a svc and dvc sub of diff sizes, even if the same brand. I'd run the bigger sub and sell off the other.
That doesn't answer my question...
Which question would you like answered 1st?
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
969
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
SoCaL081
SoCaL081
Boomin_tahoe
    May 20, 2024
    May 20, 2024
