sws10
Banned
ok i got around to wiring my system up today, and i believe i have done everything but i start the turn up the radio and the amp doesn't come on i dont know what to do?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifi HAVE a question what the terminal on my amp between the power and ground
what do you have in there?i HAVE a question what the terminal on my amp between the power and ground
your the most helpful one thats posted, i dont have anything in it, so do i need to pull out the h/u and run a wire form the amp and splice it into theback of the h/u so wherewhat do you have in there?
it's the remote, it should be spliced into the remote from your h/u. i'm sure that's your problem. if not your h/u you can run it from anything that turns on when you have your ACC on.
