help me pick a set of 8 inch subs
Vfl 8 all day. I have 2 on a 1000w alpine amp in my girlfriends Honda accord coupe trunked in 2 cubes tuned at 34hz. They are very nice. Get loud and clean for 2 8's. She got a 244$ sound ordinance fine the first day in town. They are heavier than I would of figured a little 8 to be also. Probly close to 20 pounds of pound lol.
My .02
Have read that the sq and vfl are the same sub's btw. I got the vfls on e bay for 110.00 each
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
80
588
578
southport2014
southport2014
Indianapolis, IN
Warbird40
