Help deciding setup tonight!
  • 5
ivarandri
17
iceland
Hey guys first post here! but since i sold my Cherokee and my old system with it now i need new
Used to have (Type R 500rms driven by Alpine MRP-M500 amp)
Im now looking at
2x 10" Lanzar Heritage HRWDC10 rated at 700rms each with PYLE PLAD3300D 3600Watts Digital MOSFET Amplifier
or
12" JBL 1600w rated at 400rms with Kenwood 1000w Amplifier
My speakers are Pioneer 400W 6x9 4Ohm and doors Pioneer 210W 4Ohm
Hey guys first post here! but since i sold my Cherokee and my old system with it now i need new Used to have (Type R 500rms driven by Alpine MRP-M500 amp)
Im now looking at
or
most of what you listed is pretty low end junk, that pyle will end up as a doorstop within a week to a month. Out of the two i'd go wit the jbl kenwood combo if your completely dead set on those choices. I would not run either setup.
What is your budget bro? There's way better choices out there.
X2 When I first got into car audio a long time ago, I thought pyle was awesome because it was cheap with big numbers. Boy was I disappointed, had a pyle chopper series 4k and 2 chopper 12's back in the day the amp went after about 2 weeks and the first time I put the subs on a amp that did actual rated power the coils cooked like bacon. This being said I also would not run either set up but the jbl, kenwood setup would be better out of the 2.
Neither. Give us goals and a budget we can suggest better equipment
Budged is max 417 USD, No goals just a little more bass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Btw, I Live in Iceland so it's not as cheap here the speakers and all that
1X 15"sub and a 1000wrms monoblock... maybe sell your 6x9's and buy better gear with the money
Yeah maybe i could sell my current speakers and go for Alpine speakers first then Subwoofer later.. I used to have GTi with only Alpine speakers it had alot of bass and very good sound!
I could put Type R in the back and take out the Pioneer speakers and sell them and add Type R in doors too
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
Start off by making sure the ground is making contact with bare metal. Then check that the fuse holder wires by the battery are snug. When I have...
571
ivarandri
ivarandri
iceland
ivarandri
