help deciding on speakers
I have a 2005 Chevy Siverado extended cab and I want to replace the factory speakers. I would like to hear you suggestions on what would best to install. I am looking for better than middle of the road but not top of the line or maybe top of the line depending on price. And also if they need an amp what should i get for an amp. The front speakers would be 6.5 and the rear would be 4 x 6s. I was also wondering if it is possible to install 5 1/4s in the rear. Thanks for any help you can give me?
You can make anything work if you try hard enough. The fronts are 6.5s and for the rears, with some home-made adapter plates, you could probably squeeze a set of 5.25s back there...it would be tight and might take a little trimming, but anything will just about fit anywher...just takes some work //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
junior34
junior34
jacksonville, fo
Chevyaudio
