linvillegorge
I have a HiFonics BX1000D powering 2 MA Audio XE120s wired to 1 ohm. It is less than one year old. It was working fine until a couple of days ago. Then, I went out, hopped in the truck, no bass. Checked HU settings, everything was good. Went back and looked at the amp and no power. Checked the ground and power wires and they're good. The fuses are good. I know the remote wire is getting power, because the remote wire is then daisy chained to a second amp which is running fine.
What could've happened? It just doesn't make sense because I haven't even been getting on it lately. I've ran it for hours at a time with no problem in the past. In the last month or so, it hasn't been ran over 30 minutes at a time.
I called HiFonics tech support, but they're worthless. They didn't even know what a big three was. All he did was lecture me about running the amp at 1 ohm. I simply told him, look, I didn't rate the amp stable at 1 ohm, you guys did. I was simply running the amp the way it was rated.
I can send it back to be repaired, but then that'll take weeks and I have to cover shipping. I might just throw it on eBay and get what I can get.
Any ideas before I just ditch it?
