Helium shortage...
that would be awesome, lets just hope it actually comes to fruition
yep, it's back on track.
Fusion Is Not Free - IEEE Spectrum
it looked bleak for a bit
Does Fusion Have a Future? - IEEE Spectrum
http://www.iter.org/
course, the output of Fusion isn't necessarily Helium-3...
another reason why Fusion is key to our future. Besides being an ultra-stable form of nuclear power, the byproduct of nuclear fusion is helium.
FYI - nuclear fusion (in the form currently being usedfor energy production) is the fusing of two Hydrogen atoms (at temperatures ~100x hotter than the sun).
If the sun is a giant fusion reaction, how is any other fusion hotter?
Also considering how little mass of Hydrogen you would need to fuse to power the entire planet (and the state of the heium as it is being created) I doubt that's the simple answer to producing helium by the ton!
Good luck with that whole cold fusion thing IF you did envent it some oil company would either pay you to keep it under wraps or pay to have you silenced.
we cannot replicate the pressures that the sun can, so we need to be hotter than the sun to sustain the reaction. this is achieved by creating a plasma inside the core, and controlling it with magnetic fields which prevent the plasma from touching the sides of the core (shaped like a toroid). the sun is basically fusion and fission happening constantly, but at very high pressure.
The shortage of Helium-3 is somewhat of a big deal. The main issue (i see) is that the detection systems that use it are poorly designed and we should find another way. Leave it to the DoD to create a problem that could have been easily predicted if it wasn't be ran by fools. Researchers who are upset about no longer being able to get down to 1.8Kelvin - i don't care about. We have bigger issues than that. MRI machines that require Helium-3 for cooling should win out in this battle.
as I said before, Liquid helium is very expensive to produce and takes a long tiime to do it. We had a liquid helium seperator at the lab I used to work at that was the size of 3 school busses and would only create a few ounces per hour of operation.
Also liquid helium is used to cool particle accelerators such as the one at Fermilab and LHC.
Didn't consider pressure. Makes sense.
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
quackhead
