Hearing impaired
gearbox
I am hearing impaired, I require a cochlear implant for daily communication. I do well with the implant, but the sound inside a car while driving leaves me not able to talk on the blue tooth very well. I do much better with the car in park. I deal with the obvious road noise and I have the blue tooth up loud and the quality of sound gets worse?
so my questions for you audio experts is- what things should I do to my car to help this out.
I was thinking
sound deadener (which one is best for limiting road noise)
should i replace speakers?
something for windows?
I drive a 2013 camry se v6. I am considering getting a lexus, cause I have heard the cabin noise is much better.
thank you everyone
Indeed, most "luxury" cars have much better factory sound deadening than "lower" models. It would be easy enough for you to test drive one and see if the ride was quiet enough to be worth the trouble.
Most of the butyl + aluminum foil deadeners are about the same (assuming comparable thicknesss). People use that, MLV (mass loaded vinyl), and CCF(closed cell foam) for sound deadening. If you have access to a compressor and spray gun the spray on deadener is effective as well. Any of it takes a lot of work and money.
That said, lower "noise floor" should make it much easier for you to comprehend what you're hearing and every 3dB you can drop the noise floor in the vehicle is half the power you'll need to your speakers to get the same relative effect at your ears. Likely more so since most hearing imparied people I know hear well enough in a very quiet room but amidst a lot of background noise everything just seems garbled.
I'd say you're on the right track as far as trying to make it quieter in the car. That's likely your very best (most effective) option, though it may get expensive and will be labor intensive.
Search diymobileaudio.com forum for some enormous threads of deadening materials and techniques others have used. I don't think there's any "right way", but there's a few things that consistently fail so just avoid the don'ts and you should make progress with any of the proven methods.
THank you for the detailed reply hispls. I will do some more research.
Does anyone know if I swap out speakers for betters ones can this actually help clarity. that is what deaf people struggle with ?
if I ask a stereo shop they will say of course, with and amp, etc etc etc
so i was using a 2011 yaris and the blue tooth speakers we so much better then my 2013 camry. pretty upset about that. could this just be the speakers? Its not a night and day difference but clarity is much better. took camry to dealer and they had 3 techs call from my blue tooth and said its working fine. grrr
I was upset and said how can a much cheaper yaris bluetooth sound better
I just found an amp court in the yaris by the battery. maybe the yaris is much better sound, due to the replacement of stock speakers. I have no clue if they were replaced, but it makes sense that they could be
gearbox
gearbox
Anaheim
gearbox
vegang
vegang
