I just put a headunit plus some LEDs in my car, they both worked fine until the switch for the LEDs broke. The switch was wired into the radio fuse and was a 3 pronged switch (Power, Ground, Acc). I bought a new switch today and it was two pronged. The switch was run into the headunit fuse. I had forgot what wire was what and (I think this is the problem) to find out tried different combinations of the wires on the switch and it sparked the first time. I disconnected all the switch wiring and now the headunit only works when the car is running and when the turn signal is clicked or emergency lights, the headunit turns off. This only occurs when a turn signal is turned on, and the signal; does not even blink. Can anyone help me with this or give me some idea as to what went wrong?
Any help would be appreciated, BTW the car is a dodge dakota.
Thanks
Thanks
