Heads up
zthumper
Don't call it a comeback
I have had been having a lot of trouble with my kicker zx350.2 for the past few months. It has been sent in and "repaired" 4 times now. Well i got a call from kicker and they said that they found the problem. Somehow one of the welds is messed up on the board and when they test it before shipping it out it passes the tests, however once you hook it up in your car for a while and crank up the gain the weld fails and burns up the amp. He said that this has been found in other new zx 2 channels amps so this is just a heads up if you can't figure out what is wrong with your amp. Hopefully this time I can actually listen to the slc265 comps for more than 5 minutes.
zthumper
zthumper
MW
xluben
Mike Mccabe
