Weird, I had terrible dim with my subs (2400rms at .5 ohm) and since I did the big 3 and added two yellow tops (one in hood - one in trunk) and got a new alternator (not high output, but a new stock 130amp) I have zero dim at allAdded
Try adding a second battery. Your alt should be more fine. Your electrical can't keep up with the amperage being discharged for whatever reason.Only battery is in the trunk and alt. Is 180 amps
Double check your wiring and make sure you arent running it at .25 or .5 accidently (or ideally get a DMM to check)Grounds r good and running Audiopipe ap1800 at 2 ohms
