headlights dimming when bass hits
knu is some of the best on the market. but its not exactly cheep. and i wouldnt get the klmx due to the fact that it is cca. i personally dont run anything but ofc. the kolssus flex kit would be your best bet.
hes only runnin 1.1k watts so OFC isn't exactly necessary
since when do you need 40' of wire to run your power and your grounds?
power grounds, and about 10 feet for big 3, do you know where he amps are, do you know if the alternator is acroos the cabin. ???? 40 feet lets you make sure you have enough, atleast 20 feet to the back 2 feet grounding, could be 10 feet to do big 3, ground to block, ground to chassis, and alt to power, then has to split power to 2 amps, and the knu is perfect 4 u, its oversized, more like in between 2 and 3 guage, itys huge
this guy needs to READ. not just jump into throwing stuff together. then ask why it's not working right. open your ears trucker. they've been telling you what todo then you come up with some other idea instead of LISTENING
rbtrucking
rbtrucking
west hartford ct
xoutofmyheadx
