rbtrucking
I Have a memphis mcd 1100 amp with dual jl audio 12w3v3-2 wired in parralel for 1 ohm @1100 watts rms and whenever the bass hits my headlights dim. I am running a 8 guage power and ground wire. I was told that may be too small and may be the reason the headlights are dimming. Do you you think if I upgraded to a 4 guage wire it would help the problem, or do I need to get a deep cycle battery/ high output allternator? Car is a 06 hyundai sonata. I am also running a JL audio slash 150x2 2 channel amp for my front stage, no rear fill at this time. The problem was there before I installed the jl amp for the fronts though and that has not made it any worse. What do you all think?
