Head Unit Hunt
Dima i30
21
New York
Hello,
I am trying to find a Head Unit for my Infiniti i30 1996 for under $300 with these specs;
4 Volts
F, R, S,
96db and higher
Under 300 bucks.
Can you help?
I want this to work with my soon to be bought Infinity Kappa 6.1 Components ($299)
Rear Infiniti Kappa 62.5i speakers ($149)
Maybe a 4ch US Acustics Amp 65Wats x 4ch
Thanks.
Alpine CDA-9807
CD/MP3/WMA Receiver with CD Changer Controls
Specification
Alpine 50-Watt x 4 XM™ Radio-Ready CD Receiver with CD Changer Controls and 3 Pair Preamp Outputs
Warranty:Months
Labor/Parts 12/12
Item Height in Inches 2
Item Width in Inches 7
Item Depth in Inches 6.1
Dimensions (HxWxD) 2.0 x 7.0 x 6.1
Car Stereo Type CD
RMS Power x Channels (Watts) 23 x 4
Peak Power x Channels (Watts) 50 x 4
Satellite Radio Ready Yes
Digital Radio Service Provider XM™
CD Changer Controls Yes
Disc/Station Naming Yes
Random Disc Play Yes (When used with compatible CD changer)
CD/MD Signal to Noise Ratio 105 dB
CD/MD Frequency Response 5Hz - 20kHz
Tape Dolby NR N/A
Tape Music Search N/A
Tape Full Logic Controls N/A
Tape Frequency Response (best) N/A
Tape S/N Ratio (best) N/A
Faceplate Security Detachable Face
Fits Chassis Size DIN
Installation depth (inches) 6-7/8
# of Pre-Amp Outputs 3 Pair
Pre-Amp Output Voltage (Volts) 4.0
Loudness/Bass Boost Yes
Sound Processing/Equalization Yes
# Presets (FM/AM) 12 FM/6 AM
Mono/Stereo Switch Yes
Remote Control Type Wireless
Display Colors Blue/Amber
Eclipse 5423
5 volts at 55 ohms of impedance
s/n ratio is 94-96(I wouldn't look at a s/n ratio spec on a head unit when making
a decision....the spec will always be very good and you couldn't tell the difference in a s/n ratio between 95 and 98 or 100 anyway).
Oh, and this deck is $289 and should sound excellent.
Good luck with whatever you buy.
6
565
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
820
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
850
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
Dima i30
Dima i30
New York
JLCivic
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
