Head unit distorting at volume 25 out of 35 max
mikeysheff12
CarAudio.com Recruit
So currently I have a fairly cheap head unit, it is the Kenwood KDC-168U. I was going to upgrade but I noticed there is a shortage on microchips so there are not any good, high quality ones around. I have four Kicker CS Series door speakers and a Skar ZVX-12 sub on 2k watts. I can’t figure out a way to get rid of the distorting in my speakers going past 25. They’re brand new and I thought they would fix the original problem of my stock door speakers distorting. My radio equalizer is flat all the way through so my sub can take all the bass. If need be, I will get a new head unit as soon as they come off of back order. Does anybody have any suggestions for what’s going on?
What if my current amp for my sub is pulling so much power including the fans I have on the amp that when I have my bass knob all the way up with the volume at 25, my headlights dim when the bass actually hits. Wouldn’t another amp make that effect worse. Also, how would I wire another amp if my current head unit only has one rca plugin which my amp for my sub is plugged into
Most two channel or four channel amps have a pass thru. Allowing you to run one set on RCA's in and one set out to the sub amp.
What sub amp do you have?
Now don't get me wrong, I have run a lot of Skar. But there are Pro's and Cons to that amp
Pros: Puts out more than rated power Roughly 22-2600 watts from certified to dynamic
Cons: Not very efficient 66-72% and it pulls a lot of amps. Up to 220-240 amps
So in my opinion that amp needs a second battery to see its full potential. You can try doing the Big 3 to see if that helps.
Alright, thank you. I’m doing the Big 3 today as slugbutter suggested on one of my previous threads. Would I be able to just upgrade my current battery instead of having to get a second one would it be better to get a second one.
x2, never get a deck below 4v. I can't tell you how many times I've wanted to bang my head through people's dashes trying to tune a less than 4v radio. Usually the gain has to be cranked up all the way, and sometimes you actually have to use bass boost. Below 4v RCA outputs should be highly frowned upon; that's garbage.
mikeysheff12
mikeysheff12
Hartsville, SC
mikeysheff12
