TurboTBird
Hey, I'm installing a Clarion head unit in my car it's specs are 53Wx4 or 19Wrms x 4 .
I'm wondering what kind of current it will need when turned up to full volume.
To power the deck there is a 14g yellow wire with a 15amp fuse that needs to go to a battery supply and the red 18g wire that goes to the switched ACC voltage. My cars wireing harness works in reverse. The switched 12V is available from a 14g 20amp circuit and the constant 12V from the battery is only available from an 18g 5A circuit in my car.
I suppose the yellow wire for my deck carries the current to supply the deck? Does this mean I need to run a 14g wire to my battery + terminal? That battery terminal will have 14V on it when the car is running, is that gonna be a problem or can I get a little more volume out of my deck simalar to an unregulated amp?
Thanks
Thanks
