head unit blew
schrummy
k. i blew my eclipse last weak. power wire is fine. i ran a seprate ground of it. my remote wire branches to a L.E.D volt display and to a switch from there it goes to my amp.
first time it happened was crusing with a friend. went out of town a bit and turned it up. box is tunned to 28 hz and my car just shakes.
i think it is a bad switch but im not for sure. also been told that my rca's need to be ground to the head unit.
so what im asking is what do you think it is.
Are you running your speakers off the head unit? If the wake up wire is bad which I don't know if that's what you are trying to say, just connect your wires for turn on to your red wire and your set. Also I think you don't need that much bass.
May I humbly suggest that you rewrite this post in a cogent manner, if you expect folks to help you. As it sits, it's gibberish.
schrummy
schrummy
Ames, Iowa
FJF
