Alpines and the H701 + rux 701 Controller
davidtemple
Caraudio Guru
I know few years ago I used a H701 with my alpine 9861 deck and also had the 701 controller it worked great for me in setting up my system. I sold them 701's last year now they are discontinued ( I know they show up all the time ) but is it possible to use the Alpine Imprint with an Alpine deck that is not listed?
What does all the big dogs do to setup their rides for SQ Competition?
thanks guys! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ural concert.
pioneer p9
clarion drz9255
zapco dc ref
360.2
audison bit1
probably others with similar capabilities.
I'd personally stay away from the imprint. the h100 at least. the h650 is not bad.
PPI DCX-730, if you can find one.
Oh, and I have a pair of L3s for sale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pair it with an active HU and it should. As long as it has assignable outputs, it isn't a problem. I mean, one signal input from the HU can send signal to two different amps, the 360.2 splits it and you can adjust each individually.
When I finally get around to installing my DCX-730, the HU will handle the sub x-over and midbass x-over, the high output on the 9887 will be sent to the DCX, split there into separate channels, and the DCX will handle all processing so that out is split to two separate amps. This allows for 3-way front + sub.
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
bass_lover1
Mike Mccabe
