HDC3 15's x2 151.2 *vids*
I just dont believe 7000 watts and those subs and he only is at 151 while burping....hmmm not sure, just would have expected a higher score, those amps must be hurting....I'm gettin 2 hdc3 and will be running about 4800 rms too them and I was exspecting low 150, high 140's....idk
I'm also wondering what yur electrical is....with those 2 RD amps, thats alot of power....and with that much power I would expect those HDC3's higher than that...nice score tho...
why do you expect more they are 1k rms subs, thats a great score for them.
he got a low 150s retard.
He's not seeing a full 7000 watts dude, he said no tweaking and you don't know the box specs, plus it's at 41 hz.
Great score.
**** you can run a stock alt with 7K watts...?
Gratz, btw wish i was hitting near that even though im only running 2500 watts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
btl off kx2500.1 vs btl on memphis 4kw
kx2500.1 burped higher until a third battery was added to an electrical that already consisted of a 220a HO alt and 2 g31 batts. so with an electrical that needs some work for the bigger amp...a 2500w amp beat out a 4000w amp. same car, same sub, same box, everything.
if nate ups his electrical i can only see his score going up...
I'm just saying that his electrical needs to be upgraded..it is a nice score, but it can get alot louder...I've heard one hdc3 do 146..but that all depends on the tuning, ect. Nice score...just up yur electrical and it will be alot better. I wouldn't run them daily on 3500 each tho, burping them is fine...but gl man...it is a nice score, esp at 41hz
meh, i ran mine on 3kw daily and it worked just fine. in fact, my old hdc is in his wall...
apparently you got it figured out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Was it peaking at 41hz?
Get the noise to go away?
my 3 month old rokr's battery took a dump. so i have no cell phone until monday... I guess i'll have to hit you up when you get back from sbn or something to get that back.
Good numbers man, looks solid, after a little tweaking it a little you should be right up there in the 52's. im running 2 HDC3's on a sundown 3000D and im hitting 150.2 at the headrest @ 30 hz.
that depends upon many factors. Vehicle, peak note.....
Electrical
4 kinetik 2400's in the back
1 Yellow top under the hood
2 runs of 1/0 +
2 runs of 1/0 -
2 RD 3250.1
voltage dropping to 13.2
stock alot had an Ohio Gen but it took a dump long story.....
Box is 11 cube net tuned to 32 hz
it peaked the score at 41hz (not alot of testing done at all.
also on music it was doing a 150.8 on Jeezy
for being tuned that low and for daily beat it aint that bad at a score.
I think Tommyk with a zx2500.1 and a 15 or 12" type r he was doing 150 easy.
when you get your setup lemme know and when u start hitting 150's on music lemme kno
nate2587
nate2587
Lambertville, MI
nate2587
