Sold Hcca 2 12.4's G2g
monkeyman22
Have two of these bad boys but newborn is coming up soon and well these gotta go //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif throw me some offers
# 12" HCCA Series Subwoofer
# Sensitivity: 84 dB
# RMS Power Range : 2000 Watts
# Peak Power Handling: 4000 Watts
# Impedance: 4 Ohm
# Diameter: 12 Inch
# 4" copper Wound Voice Coil on an Aluminum Former, High temperature Polyester Amide, Amide Resin Coated
# Continuous power handling will be 1500W (under rated)
# X-Max estimated at 30mm (total travel 4 peak to peak)
# Field Replaceable Cone / Voice coil / Spider Assembly
# Dual Flat Spiders with Loop/Stitched Tinsel Leads
# Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
# Enhanced voice coil cooling system forced convection with aluminum heat sinking shorting rings to reduce inductive heating)
# Dimensions (in) 11.9 x 10.7
[/URL][/img]
i already explain why it did that when i submitted my thread the first time i guess my internet was messed up so i clicked a few times til it did submit and it came out that way. for the subs i want 750 subs +box
monkeyman22
monkeyman22
carson , ca
monkeyman22
michigan born
    May 14, 2026
michigan born
    May 14, 2026
