Haze behind dash cover
Montypup
I have a problem with a haze/cloud that has formed on the back of the plastic covering my readouts (speedometer, tach,gas, ect). I gave my sister my keys to get a cd out of my car and for some reason she rolled down the window and never rolled it back up. It rained overnight and when I woke the next morning the haze had formed on my plastic. I figured it would go away but it's been a month and it's still there. Is there anyway to make it go away without pulling the dash off? WIll it clean off or will I have to replace the cover? The car is a 1997 Infiniti I30.
Haze= Condensation
Nothing is wrong unless your guages are messed up, if not, you are fine. But it cant be fixed without taking the dash molding off. There should be two or three dash covering that are around your sterring column, they simply pull off. Then you should see a couple screws holding on the plastic sheild for the guages, unscrew those and wipe down the shield, put it back together. Total time - 15 minutes
Very simple to do
Well, I've never really done anything like this before, so it'll be interesting. I'll give it a shot and worse come to worse I'll take it up tp my local shop. Thanks dude.
Montypup
Montypup
Tulsa, OK
Montypup
