Having trouble making circle cuts
BigSix
Whippin the Bass
I just recently built my first box.....although it was a badly built box(not properly sealed or straight cuts) it was quite a learning experience. I bought a POS black and decker jigsaw to make the baffle and speaker terminals and they were the worst circles i ever seen...... so now i decided to buy a router but unsure what kind i need... plunged?? fix base?? also what are some good brands and what kind of accesories do i need with it to make perfect circles????
any input is greatly appreciated!!!!!!
bigsix,
might as wel get the plunge router over the fixed base, considering many routers can be locked in the "plunged" mode making it just like a fixed base.
I just bought a router as well, but havent had a change to play with it yet.
plunge base, and a circle jig (you can make your own) i cut my circles with a jig saw, just go sloowly
I think its impossible to make straight circles with the pos one i bought the jigsaw doesnt stay straight....
I cut a circle with a jig saw in less than 30 seconds. Just follow the line...
You just constantly have to track the line turning the back of the jig outwards as you go... It's very very easy.
I actually use a rotozip sometimes.
you shouldn't have to worry about going straight, You're making circles.
What i meant by that as in a straight circle was straight cut from top to bottom ....the jigsaw is cutting circles but at a angle.....
im sure i i had actually bought a decent jigsaw instead of black n decker then this would of been possible......anyone else ever use the same jigsaw and got good results????
so the trick is to twist it from the back???
Yep. Kick the rear of the jig outwards from your circle as you go forward. Never move the jigsaw in a left/right motion as this will bend the blade and angle cut. Make sure you apply plenty of force on the jigsaw. Keep it pushed down in to the surface you're cutting to prevent any left/right motion.
I sometimes use a $20 black and decker and can cut perfect circles i just follow the line //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you want to do it right (and fast) get a decent plunge router and a Jasper circle jig (from parts express). Use a solid carbide upcutting bit (try mlcswoodworking.com for good prices). Best investment you'll ever make if you make multiple boxes and different diameter holes.
BigSix
Whippin the Bass
BigSix
Austin,Tx
dappa5
vegang
vegang
