having problems
TexasMade
i recently upgraded(or at least tried to) my factory shaker system in my mustang, i have 2 12 inch sony xplode subs and a 1200 watt power acoustik amp . Being low on funds, i did not have the privelege of being able to replace my factory head unit so i had to use an rca converter because te head unit does not come with rca jacks i cannot seem to get any where the same type of power that i used to get from the same system is there anything i can do or maybe wire anything different?
did you adjust the gain on the line converter? you might want to read the instructions if you havent, might help with the output.
edit, just realized what section this is in, i dont think you will find the help you need in this area.
where am i supposed to post? 1st time here, buty yeah i've spent hours trying to adjust it, even my amp but i also cant seem to turn my amps power level to more than about a quarter of the way without it sounding like u know what
TexasMade
TexasMade
El Paso,Tx
nVRuckus
