Have you made full use of iPhone, iPhone 3G?
orangesea
The last year released iPhone 3G. A lot of people choose iphone as their communication tool and entertainment player for its powerful functions. People not only regard it as an phone but also a music and video player. Now I will share my experience to use a useful tool 4videosoft iPhone Mate to make use of iphone.
The following text will be divided into four parts.
First: How to put dvd on iphone?
Second: How to convert video for iphone?
Third: How to transfer iPhone files to Computer, import PC file or folder to iPhone and transfer files between two iPhones?
Fourth: How make ringtone for iphone?
Tips: How to make wonderful DVD/video editing (Merging, Trimming, Cropping, Effect adjusting, Capture picture)
Before the article, I will explain general knowledge about iphone.
Video formats supported: H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per second, Low-Complexity version of the H.264 Baseline Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;H.264 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Baseline Profile up to Level 3.0 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
Audio formats supported: AAC, Protected AAC, MP3, MP3 VBR, Audible (formats 2, 3, and 4), Apple Lossless, AIFF, and WAV
First: How to put dvd on iphone with 4videosoft DVD to iPhone Converter
Step 0. Run 4Videosoft
DVD to iPhone Converter.
Step 1: Import DVD.
Place the DVD into your DVD drive and click the “Load DVD” button to load DVD.
Step 2: Video settings.
Select the output video format you want from the “Profile” drop-down list.
Step 3: Place video
Click “Open Folder” button to open your output destination file.
Step 4: Start conversion
Click the “Start” button to start your conversion and in a short while it will be finished.
Second: How to convert video for iphone with 4videosoft iPhone Video Converter
Step 0: Download and install 4Videosoft iPhone Video Converter
When you finished the download process, run the .exe file to install it.
Step 1: Click “Add files” button to import videos.
Step 2: Extend the "Profile" category to select an output format.
Step 3: Click “Open Folder” button to open your output destination file.
Step 4: Click the “Start” to convert.
Third: How to transfer files between two iPhone , transfer iPhone files to Computer, import PC file or folder to iPhone and with 4videosoft iPhone Transfer
3.1. How to transfer songs and videos and other data between two different iPods.
Step 1: Download and install 4Videosoft iPhone Transfer
Step 2: Connect iphone
Connect your two iphone to your computer via USB cable.
Step 3: Find your data.
Open the library/playlist that you want to export files. Pick the files that you need to transfer.
Step 4: Transfer data
Just click “ipod to ipod” button and it will show you the folder of another iphone that you want to transfer to. Click OK. The transfer can be finished automatically.
3.2. How to backup iphone data on your computer.
Step 1: Connect your iphone.
Run the software, and connect your iphone to your computer via USB cable. After done, the iphone icon and its library and playlists will appear in the Device list.
Step 2: Find your files
Open the library/playlist that you want to export files, and then check the file(s) you want to export in the file list.
Step 3: Backup files
Click “ipod to computer” button to select the destination of the exporting files and start exporting files.
3.3. How to transfer songs and videos from computer to iphone without iTunes.
Step 1: Connect iphone.
Connect your iphone to your computer via USB cable.
Step 2: Find data
Click “computer to ipod” button to seek the files or folders that you want to import to iPod and click OK. The process of importing will be finished instantly.
Step 0 : Download 4Videosoft iPhone Ringtone Maker
Step 1: Click “Browse…”(Button 1) to import the file(audio or video file) that you want to make ringtone from it.
Step 2:Click Episode button to listen the music to find what you want as ringtone.
Area 1: Drag the start & end slider to set your wanted episode
Area 2: Type the start & end time in the corresponding text box directly to get the exact episode.
Step 3: Click Whole Button to pre-listen the converted audio before generate.
Step 4: Click “Browse…”( Button 2) to choose the output destination.
Tip 1: Check "Export to iPhone" option, the converted ringtone will be loaded to your iPhone directly.
Step 5: After all the settings are finished, click “Generate”( Button 3) to begin making your own iPhone ringtone.
1. How to change your video effect
If you want to adjust the effect of your movie, please click the “Effect” button and a pop-up effect window will appear. It allows you to edit your movie’s effect including “Brightness, Contrast, Saturation and Volume”.
2: How to crop off the black edges and adjust the size of video play region
By using the "Crop" function you can crop off the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices
3: How to split your video
The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the exact time-length of the clip or you can directly drag the slide bar to the position you want.
4: How to join the videos
If you would like to put several files into one output file, please tick the check box of the “Merge into one file”.
5: How to save your favorite picture
If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button, the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture.
If you have a iphone/iphone 3g/iphone 3gs, I recommand these three converters to you which can give you a help to convert iphone files to Mac or PC.
iPhone 3G to pc is an easy-to-use iPhone 3G to computer transfer, iPhone rip, iPhone backup software can fast transfer, rip, copy and manage your music, videos, photos, podcasts and TV Shows between iPhone or iPod and computer even without iTunes. With iPhone 3G to PC transfer, it will help you a lot.
With the professional iPhone 3G to pc, you create, edit and delete iPhone and iPod playlists. What's more, The powerful iPhone to PC Transfer provides three functions: import files to iPhone, export iPhone files to pc and add files too iTunes library.
iPhone 3G to Mac is an easy-to-use iPhone to Computer transfer, iPhone rip, iPhone backup software can fast transfer, rip, copy and manage your music, videos, photos, podcasts and TV Shows between iPhone and Mac even without iTunes. All formats compatible with iPhone/iPod are supported.
Moreover, iPhone 3G to Mac helps you create, edit and delete iPhone playlists. With the professional iPhone to Mac tools, you can copy files among multiple iPhones simultaneously.
You may also need this excellent iPhone 3G converter, which can easily and quickly convert WMV, RMVB, MOV, DAT, VOB, MPEG, FLV, AVI, DivX, XviD, etc. to iPhone movies MP4, widescreen iPhone MP4, iPhone 3G MP4 video or iPhone 3G H.264 video for playback on Apple iPhone with the fastest iPhone Movie Conversion speed.
orangesea
orangesea
beijing
chaunb3400
