Hard decision to take... JBL or Memphis
hemos
I need 1 amp for my front CDT HD-652 components and one for my eD12o.44 Subwoofer. I have to make de decision of go with either JBL or Memphis. Here are the descriptions of the amps :
Memphis 16-MC300
RMS Power 4ohm 150x2
RMS Power 2ohm 240x2
THD 2/4ohm 0.03%
S/N Ratio >88db
Variable Low-Pass Filter 50-250Hz
Variable High-Pass Filter 50-250Hz
Filter Slopes 18db
Input Sensitivity 250mV-5V
Input Impendance 20kohms
Frequency Response +/- 1db 10Hz-50KHz
Fuse Rating 25A*2
Memphis 16-MC500D
RMS Power 4ohm 250x1
RMS Power 2ohm 500x1
THD 4ohm 0.50%
THD 2ohm 0.75%
S/N Ratio >80db
Variable Subsonic Filter 20-50Hz
Filter Slopes 18db
Input Impendance 22kohms
Frequency Response +/- 1db 10Hz-650KHz
Fuse Rating 25A*2
JBL P80.4
RMS Power 4ohm 40x4
RMS Power 2ohm 80x4
RMS Power 4ohm Bridged 160x2
Minimum Speaker Independance 2ohm
THD 4ohm 0.05%
S/N Ratio >100dB
Input Sensitivity 250mV-4V
Fuse Rating 20A*2
JBL BP600.1
RMS Power 4ohm 300x1
RMS Power 2ohm 600x1
Minimum Speaker Independance 1ohm
THD 4ohm 0.10%
S/N Ratio >90dB
Frequency Response +/- 1db 10Hz-320Hz
Fuse Rating 30A*2
I can get the JBL package for around 335US and the Memphis for 515US. I just don't know which ones to take. Can someone help me to figure out these numbers ?
Thanks,
Maxime
if the $180 difference is not that big of a deal to you...then i'd go with the memphis. But, if it were me...i'm about getting the rms power i need w/ least amount of money...and i'd go jbl. BUT, the memphis is better quality IMO, so if u got the money...go with it. peace
NG
If you have the $515US for the Memphis package, go for it.
Si vous avez le 515$US pour le packet de Memphis, allez pour il.
Seeing that you are in Canada, check out http://www.genuinecanadianaudio.com and look at the Interfire amps. Saves on the exchange rate and border fees. Very high quality amplifiers.
Voir que vous êtes dans le Canada, payez la note http://www.genuinecanadianaudio.com et regarde les amplis de Interfire. Très les amplificateurs de qualité supérieure.
- Steve
You **** Steve. How long did it take your wife to translate all that for you? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
French is easy //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
- Steve
Lol.... I read your posts in English... and after in French to be sure to understand well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I guess I'll get Memphis or Interfire... will take the week end to look at that
The Memphis would be a very fine choice.
See what you can put together with the Interfire amps ... they seem to be of just as high quality.
- Steve //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hey who wants to sell me a memphis belle
If I had one, sure //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
They're sweet amps ... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
hemos
hemos
Montreal, Canada
denim
