Hafler amps
Active means using one amp for your mids, the other amp for the tweeters.
You dont use the crossover that comes with your components, it requires a crossover in either the head unit or a separate one to split the frequencies.
they are way cleaner power than the Kicker...but the Kicker is about double the power.....most likely too much power for tweeters...you may want to run one Hafler on your tweeters...and if you have the kicker...use one set of chs for your mids....and if you have rear speakers use the remaining chs on the Kicker for them
ZO6killinsbf
Beer is good
ZO6killinsbf
McKinney, TX
bigdwiz
