You've had multple people tell you a place like Autozone cannot properly test your HO alt. Accept it. Your alt is just fine. If you're really concerned, go back and play a 50Hz burp at high volume. Autozone may not appreciate it, though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifThey hooked large clips to the batt, and then a clip around the + Big 3 wire. I watched the machine say the exact rpm and current, then the same test at idle.
Um, nobody said they cant do it....You've had multple people tell you a place like Autozone cannot properly test your HO alt. Accept it. Your alt is just fine. If you're really concerned, go back and play a 50Hz burp at high volume. Autozone may not appreciate it, though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and i bet they put little alligator clips on it to measure the current, theres a reason why we use 1/0 it carries the power.
autozone and advanced can't properly test HO alts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifExactly.And they have NO idea of the RPM that its spinning at.They just say "yep it puts out but I don't think its a high output"http://audioforum.termpro.com/topic/22/3982.html
A link as to why.
they use large alligator clips with 2awg or sometimes 1/0 for voltage and a ring clamp for currentand i bet they put little alligator clips on it to measure the current, theres a reason why we use 1/0 it carries the power.
It's accurate enough to prove that your alt is not providing the power your amp is demanding. What does your HU say when you aren't at high volume? 13.8 or so? What type of battery do you have? It plays a big role in your electrical, even if you have an HO alt.Also, Im currently powering only 1 of my 2 RE MX15's with a 1000/1v2 and Im getting some decent voltage drop to about 12v. NOW, this is the reading off my HU so Im sure its a little off.
Wow, very very good info. Thank you.http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=22;t=003982;p=0Read the thread.It will provide you with good info.
Then your advance is the exception, not the rule.why not? if they know what they are doing they can. The advance that I Work at can at least? an tell you that my planet audio amp draws 163 amps of current playing a 27 hz note, and my alternator will put out 254 amps at 3-3.5k rpm.
