Haaaaaaaaaaaaaaaaaaaaaamilton!!!
How does no one on here watch Formula One //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
LOL that you think Ferrari will win this. Hamilton will blow the ****ing "doors" off Ferrari. Remember, Schumi no longer exists, and Massa just isn't on par with VMMc this year.
Drag and autocross is where its at. Doing left hand circles for 2 hours is dumb. Yea I know it isnt easy but when you actually have to down shift it from 6th to 2nd in an autocross while 2 footing a clutch to keep the turbo spooled, that isnt too easy either. Also trying to setup your engine using gearing, trying to maintain traction, and changing shift points to get the fastest 1/4 possible versus just trying to go as fast as possible and have more power than the other 20 cars (i dont know how many nascars there are), isnt easy either. Just my opinion.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif :uhoh: You do realize that Formula One is THE most technical form of racing that exists? Any sport that independently adjusts the canards on the front in hundredths of degrees to get maximum performance in any given gear is a bit more engaging than doing circles...
And I am an avid SOLO driver as it is, but it doesn't even compare to 2.4 litre engines making 800hp at 19000 rpm attached to 7 gear transmissions with clutches as small and as light as your fist.
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
