h/o alt
spl_stratus00
car audio noob
i have a 2000 dodge stratus 4cylinder 2.4l and i want a h/o alt but i cant find one over 90 amps im going to run an xtra bat in the trunk and my system wil be roughly 1600 watts rms so that about 180 amp pull how can i manage to not kill my electrical system //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
get a Kinetik 1800, do the BIG 3, and hope for the best honestly. You really won't know till you do it all, but if you exercise some self control on the volume knob you should be fine //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
eddie
I ahve an 03 Stratus, I'll be running 900- 1000 watts RMS, I'll be doing the BIG 3 in a couple weeks along with upgrading my battery to the biggest yellow top that will fit my car and budget since I'm not planning on installing a second battery, and they don't have an option for a larger than stock alt on the 4G64 motor.. Should be able to swap from a 4G63 though.. I'm not sure.
run all 0g wire, and def. do the big 3 before the batt. trust me, it helps a ton. u shouldn't have all that big of a problem with only 1000 watts, but it helps a bit with dimming/minimal voltage drops
spl_stratus00
car audio noob
spl_stratus00
princeton,ky
Dak446
NorthFramingham
    Jun 30, 2026
