mschramek
Ok Im a little confused and would like some help with determining what guage wire to use for my amps. I currently have two amps- 1 Pioneer Premier PRS-X720 Rated at (1 ch: (4 Ohm) 750Wx1) and 1- Fosgate Power amp rated 50x4 at 4ohms.
The question is I have 4 guage wire running from the battery to the trunk. I will need a distribution block to seperate the wires. Should I get a 4ga to 4ga distribution block or a 4ga to 8ga distribution block.
Also will it be wise to get a distribution block for my ground as well. Or should I just find different ground points. In that case will different ground points create a ground loop.
Thanks for you help..
