jdawg
a group 31 isnt just a group 31. What model? You may want to stick to a powermaster, yellow top, exide oribal, deka intimidator, etc.
shouldnt need to unless you plan on doing a lot of playing with the car offthats good to know and I know with the added battery will I need to add a battery isolator?
here's my drops with big 3 and g34 Exide up front. before the HO alt and G31THIS is very true.........but i've had-used several kicker amps and never ran a 2nd battery. each his own though and if you get a signifigant voltage drop then a 2nd one is in order i guess. kicker has never told me i needed another battery before though, not even when i was running a bd1000 and kicker 650.4 did i use another battery, a 75 farad cap did enough for voltage. not trying to argue or anything. i'd get a kinetik only because they have a very small footprint and are reasonably priced.
The current draw on 2500 watts (underrated, so probably around 2750) is quite large, and a beefier electrical system never hurt anything, so I would say he should go for it.Why do you need a 2nd battery dedicated just to a kicker 2500? with the big 3, 0 guage wiring,and "maybe" an upgrated front battery....i wouldn't think you'd even need a 2nd battery. //content.invisioncic.com/y282845/emoticons/imo.gif.3a57bcc70a4835dc53e86ffae1a0b041.gif
capacitors are useless, this has been stated tons of times in this forumTHIS is very true.........but i've had-used several kicker amps and never ran a 2nd battery. each his own though and if you get a signifigant voltage drop then a 2nd one is in order i guess. kicker has never told me i needed another battery before though, not even when i was running a bd1000 and kicker 650.4 did i use another battery, a 75 farad cap did enough for voltage. not trying to argue or anything. i'd get a kinetik only because they have a very small footprint and are reasonably priced.
you is correct sircapacitors are useless, this has been stated tons of times in this forum
system on? like a party or something? then you need an isolator so you can drive away.yes I plan on having it off for extended periods of time.
yes kicker said it was highly recommended you do realize that the 2500.1 d amp is capable of putting out 3000 watts right? and you need power to get power.THIS is very true.........but i've had-used several kicker amps and never ran a 2nd battery. each his own though and if you get a signifigant voltage drop then a 2nd one is in order i guess. kicker has never told me i needed another battery before though, not even when i was running a bd1000 and kicker 650.4 did i use another battery, a 75 farad cap did enough for voltage. not trying to argue or anything. i'd get a kinetik only because they have a very small footprint and are reasonably priced.
yep. he's thinking smaller, low power setups. and he's right for that, minus the cap.yes kicker said it was highly recommended you do realize that the 2500.1 d amp is capable of putting out 3000 watts right? and you need power to get power.
I know it is an opttima not sure of the model# yet I have to go and look at it,it is sold by Interstate Batteries.a group 31 isnt just a group 31. What model? You may want to stick to a powermaster, yellow top, exide oribal, deka intimidator, etc.
? optima or interstate? do they own each other? idfkI know it is an opttima not sure of the model# yet I have to go and look at it,it is sold by Interstate Batteries.
//content.invisioncic.com/y282845/emoticons/thankyou.gif.5451126d09e870f796f50c3a4dd5acd7.gifInterstate and Optima are the same comapnies.
