Grounding Question
nambi
I installed a JVC indash receiver in my 2004 Honda Civic. I took it to a small local shop to get it installed and assumed everything was well. A week later I tuned into an AM frequency and I could barely make out the speech due to poor reception.
My FM reception is fine, I took my car back to the installer and he verified the antenna was connected.
I have a 2004 Honda civic with the antenna built into the rear window. I'm not sure if this is the cause of the poor AM reception or that I got a faulty deck. The factory deck had no issues with reception. FM works fine, but I notice on AM there is so much static and noise that when I drive I can actually here my engine as noise through the speakers, I can even hear the noise change when I change gears.
Would anyone know if this could be fixed by grounding?
You can try running both power and ground direct to the battery. use just 16ga speaker wire and run it outside the car first to see if that solves the problem.
trie relocating the ground either you or if its still coverd the shop usually the grounds for decks are not that good, if ur getting FM its probly not fault probly just a poor ground
nambi
nambi
tORONTO
NewToTheGrounds
