Ground wires for HU :(
pyunny
I'm new to this stereo stuff but plan to install
a HU i got by myself because it costs too much
to get it done professionally. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I got a JVC KD-G420 HU that has a ground wire but the
wire harness that I have for my Nissan
has 2 ground wires, one with the rear speakers
that is specified as just ground and another that
is with the other wires and says is for Chassis
Ground (12V-). The back of my headunit also has a
metal tab on the back that says "rear ground terminal".
What i was thinking I would do is attach the Chassis Ground
to the ground cable from my HU and then attach the
other ground cable to the metal tab? Sorry I really don't have
much of an idea of what I'm doing but hopefully if anyone can help
that'd be great.
this is the back of my HU btw:
the guide just says "match and connect the appropriate wires from the car stereo connector to the appropriate wires of the plug provided with your stereo. For example, connect the 12 volt accessory lead of your stereo to the red wire on the Car Stereo Connector."
and it also says
"tape all unused wires to prevent short curcuiting"
if it's true that nissan harnesses have no ground i wonder
why my wiring harness put ground wires -_-;;.
so should i tape up the ground wires on the wire harness
and then just ground the wire from the headunit manually?
I think i'm supposed to connect the grounds wires to something
metal right? -_-a?
pyunny
pyunny
Los Angeles, CA
azeroth123
