Im not too clear on what size ground wire I should use for this setup. Im hoping some of you guys and gals could clear this up for me. Im currently running a 4 gauge power wire to a 300w x 1 (2 ohm) amp for my sub. I will be adding another amp (40W × 2 - 4 OHM) for my door speakers. I bought a fused distro block that has one 4 gauge IN and two 8 gauge OUT. My question is ... what size ground wires should I use coming out of the two amps, 4 or 8 gauge? The distance between the amps and the ground spot is about 3 1/2 ft.
Also, I should be good buying this additional power/ground wire from Home Depot or Lowes since they are short runs, right? These short runs will not require any intricate bends or turns.
Thanks in advance.
OC
Thanks in advance.
OC
