S slim217 10+ year member Member 125 0 illinois Jan 5, 2012 #1 is it ok to run a long 4 gauge wire from second trunk battery to engine block i thought u were spose to have the shorter the better Click to read more...
OP S slim217 10+ year member Member 125 0 illinois Jan 5, 2012 Thread Starter #3 i have kenetic dry cell in trunk whats best way to ground mechanic said take it all the way back to engine block and ground it there
RangerDangerV2 5,000+ posts CarAudio.com Veteran 5,050 10 st cloud MN Jan 5, 2012 #4 just put it to the negative terminal on the battery...
OP S slim217 10+ year member Member 125 0 illinois Jan 5, 2012 Thread Starter #5 i thought the shorter the ground was better tho
RangerDangerV2 5,000+ posts CarAudio.com Veteran 5,050 10 st cloud MN Jan 5, 2012 #6 ^^ why??? a ground directly to the neg battery post will be your best bet
brooklynjoy2008 10+ year member CarAudio.com Elite 627 1 ohio Jan 5, 2012 #7 Thats when using a chassis ground.
brooklynjoy2008 10+ year member CarAudio.com Elite 627 1 ohio Jan 5, 2012 #8 i have kenetic dry cell in trunk whats best way to ground mechanic said take it all the way back to engine block and ground it there Click to expand... If u r gonna run it all the way to the front just hook it to the battery
OP S slim217 10+ year member Member 125 0 illinois Jan 5, 2012 Thread Starter #9 then should i take ground from the kenetic to amp or put distribution block from main wire and split one to amp and one to kenetic
brooklynjoy2008 10+ year member CarAudio.com Elite 627 1 ohio Jan 5, 2012 #10 No to batt. Then amp. If u look in wiring section there is a thread that shows how.
joshy629 10+ year member CarAudio.com Elite 523 8 lawrenceburg ky Jan 5, 2012 #11 do a front ground then a body in the back.
