pioneerpimp
ok first of all, i have a stock alt.. second of all i have two AQ's with two orion 2500D. i have 4 everstart batteries wired in aprallel..two runs of 0 to the back dist block from the front wired in aprallel thru the batteries..then the negative from the front there is a run of 0 thru the negatives on the back batts to a dist block for the grounds on the amp. now my subwoofer keeps cutting in and out. if i turn it up too loud and the amp will click off and then on for about 2 secs...also the alst terminal before the distribution block and the alst run of 0 guage on the batteries gets very very hot...but as far as i can tell its only that terminal. when this happens my voltage is between 13.4-13.7..can someone try and help me. thanks for all the help in advance and also the constructive criticism. thanks in advance.
