AbbaZabba
Well figured I should get on here again, used to have an account years ago but I'll be damned If I can find the log in info or even the email address I used hahha.
Anyways I have always had a system in my rides, mostly daily drivers. Dabbled a bit into the SPL scene back in the 90's, ALOT has changed since then holy hell. Just trying to catch up with things.
Current setup.
I am limited for space as this is in my Nissan Titan.
I'm running Two 10'' PSI audio Platform 2 dvc 2ohm, in a sealed box. Powered by an old *** Orion 2400d amp.
I would like to find some opinions on some different amps capable of powering these to their potential at 2ohm. Wiring upgrades are not an issue I intend to get a h/o alt and a good battery, big three already done running 1/0wires. They are rated for 1500watt rms and 3k peak each. I was dabbling with the Idea of running one or strapping two Sundown SAZ-1500D V.2 together.
Just here to gather some info on what's good out there right now. I still need to get my component setup and my head unit. Just running off the factory for now.
Current setup.
